I have an 8800gts and a monitor that supports DVI, but i dont have a DVI cord. My question is, would it be worth it to order a DVI cable? would it look any different?
with decent vga cables... resolution up to 1920x1200 does just fine..
DVI cables I have plenty... 10+ and counting from 2 to 5 meters..sl-dvi-d, dl-dvi-d. dl-dvi-i,HDMI/HDMI to DVI, and my multiple Nvidia 8800 series and 7 series are powering 3840x1024 through vga and multiple 1920x1200 and 1920x1080 and some 1280x1024 displays through multiple dvi and vga inputs. And decent/good built/proper shielded vga does not mean really expensive... I never buy my cables exceeding USD 10.If you think buying a really expensive VGA cable just to be almost as good as a cheap DVI is a good idea then you're insane. DVI will always be better, also with short (less than 3m) lenghts all DVI cables are the same (perfect). Oh and the quality of the VGA is also based on the ADC inside the LCD so your comment is pretty meaningless. The short answer is if you have bought a Nvidia 8800 card it's silly not to buy a DVI cable. Exce: go and get a DVI now before we all murder you =).
Ok, then I'll fall back on to my previous point about all DVI cables being better than any VGA then. Also the one about all monitors having different ADC's is pretty valid since a cheap monitor is not going to have a very good one. Since all computer video signals are digital as are LCDs why convert it twice just to stubborn about old technology? I've used 6 LCDs now and they all look blurry using VGA compared to DVI, so I cannot agree with you at all.
I have a question... Can better DVI cables increase the quality of the picture?
i think you need buy a better display card/VGA cable
i've tested on my CG220,i can't see any different on VGA/DVI input.the resolution is 1920x1200.
and yes,DVI are better than VGA when you using LCD with cheap equipment.
