Will this work?
toader
Pretty dumb question here....well, for you all at least.
I am getting an NF7-S, with a Barton 2500+, and I am looking for HS and Fan for the CPU.
I need to know if this fan will work or not. The reason I am asking, is because the mobo and barton say that its socket A...this fan doesnt specifically say its socket A, thats why I am asking.
This is also another FAN that I am considering.
Which one do you think would be the best for the mobo/cpu I will be using. I plan on OC'ing it to 3200. Ive heard good things about the Zalaman, but geeez they are HUGE, I dunno if I will have enough room for it in this case.
What do you guys think? If the Zalaman will work for my particular socket type...is it the better cooler? And will it fit in this case with a graphics card?
Thanks.
