Will this work with this...
Yes it will work. I'd strongly recommend getting a newcastle core instead of a precHott core...damn things are too hot...
yes, it will work.
and newcastle is an athlon64 core, im sure you mean northwood.
Hah, Yup, don't I look like a retard, heh. It must have just been a !!!!!! freudian slip or something.
the two should work ok, but you're going to need a hsf the size of nyc to cool it. better a northwood core. they don't go as fast, but they aren't as fast as a diesel engine, either. :D
I don't think it will. That chipset doesn't support 800MHz CPU's directly. It supports overclock speeds up to 800MHz. Which means likely you will never get that far.
Also that board having that chipset, it's likely that it wasn't designed with Prescotts power and thermal considerations in mind. I would get a different board.
The Intel D865PERLL is a good choice as is the Asus P4P800's.
that combo won't work. It doesn't support the prescott.
I'd recommend the 865 Neo if you want to stick with MSI. Otherwise I'd go with the Intel 865PERLL
I think it work becasue it said it does support prescott and its not a 800 mhz chip only a 533Mhz so....tell me if i am wrong
Theres more to that puzzle than sheer bus frequency. Voltage requirements are different on Prescott CPU's. Voltage requirements for that CPU weren't published until the 800MHz FSB Northwoods came out. Even then some of the earliest boards weren't built for that spec. Theres no way they could have built that board to run a Prescott before the 800MHz FSB Northwoods came out.
Prescotts run at different voltages than Northwoods Plus if the BIOS doesn't support it, you'll go nowhere. Finally websites can be wrong when it comes to CPU support.
there are 1mb cache 533mhz Prescott processors (the new "A" models listed at 2.4, 2.6, and 2.8 ghz).
cheers,
dave
