Will this void my warranty?
computersmakemeQQ
:confused:
Hi all:
I originally was planning to "sleeve" my cables with electrical tape; however, a large group of people told me it would turn out as a sticky, gluey mess. Some other member mentioned using RIT dye to dye the cables (I take no credit for the idea). It involves soaking the cables in hot dye and then rinsing them off. Will this void my warranty?
Also, if anyone has experience with this, is it okay just to soak the cables in cold dye?
TL;DR: Will dying my cables void my warranty? (I have a Corsair TX650, dunno if it will make a difference). Does anyone have experience with RIT dye?
Why the would you want to do this for? It sounds like a completely dumb idea with no benefit, and yes, I think it would void your warranty.
yes it will void your warranty, I would just use a sleeving like the rest of us do :)
