Will this replacement case fit my Shuttle?!
aznpxdd
I have a SN85G4V3 and I want to replace the sides of the case with this: http://www.frozencpu.com/win-112.html
Here's a pic of my case for reference:
It looks like it would. At $10, that is a STEAL. It is so cheap, it might be worth it to buy it just to possibly mod it in if it does not fit.
Just email the company if you want to be sure.
Yeah, it seems that it'll fit but I don't want to risk it even if its only 10$. And yeah, it looks like it'll be good for modding. I plan on painting it and cut some holes.
