Will this PSU run this system ok?
Lone_Star_Lynch
My dad is looking to do an upgrade to quad core and that and we're on a pretty big budget, cause I just got a 1200 dollar dream machine :p.
Here's the PSU we have right now: http://www.newegg.com/Product/Product.aspx?Item=N82E16817103942&Tpk=true+power+430
What I need to know is if it will run all this plus a few hard drives:
http://www.newegg.com/product/product.asp?item=N82E16813130081
http://www.newegg.com/product/product.asp?item=N82E16819115017
http://www.newegg.com/product/product.asp?item=N82E16820145184
If not, if it'll be unstable, than I'll get a new one.
Why a 650i board for your dad's machine? Does he need SLI? If not, spend a few more dollars on a P35 board -- an IP35-E or similar. They run cooler, for one.
What graphics card? You'll need one, as there's no onboard video.
It should be fine, but I'd still replace it. I've had nothing but bad experiences with Antec branded PSUs from several different series, though I understand the TP3 are at least better than the TP2 line.
Thanks for the advice, I'll take a look around. And we have an old 6600 pci-e card lying around, so that's not a problem. He might want to get into gaming in a little while, sowe can upgrade the card then and maybe get some sli action going.
If not the Antec, how about this? Nice, cheap, good reviews. http://www.newegg.com/Product/Product.aspx?Item=N82E16817189005
That should be fine, yeah. Though for $30 or so more you should be able to pick up one of the Corsairs (which are single rail units and have active PFC unlike the Xclio).
s-c hates antecs. :p Though, he's right, the TP3 line is better than the previous generation, which is ok, but not great. The Earthwatts line is better, but still not as good as the Corsair HX line (both lines supplied by Seasonic). I'd go with one of these instead, and should fit your power needs accordingly:
$70 - Antec earthwatts EA430 ATX12V v2.0 430W ($30MIR)
$70 - Corsair CMPSU-450VX 450W PSU ($10MIR)
The XClio Goodpower is great if you're on a budget and don't live in 90°F heat. The unit doesnt perform well under high heat and may fail.
This RAM is cheaper and performs the same as the Corsair. Get it while you can. You have to be subscribed to Newegg's newsletter to get the discount. New signups could take up to 24 hours:
$85 - G.Skill 4GB(2x2GB) DDR2-800 F2-6400CL5D-4GBPQ ($20 off code: EMC1213SYME01)
I agree with s-c, go for a P35 board instead:
$90 - aBIT IP35-E LGA 775 Intel P35
$86 - Gigabyte GA-P35-DS3L LGA 775 Intel P35
$130 - Gigabyte GA-P35-DS3R LGA 775 Intel P35
$120 - abit IP35 LGA 775 Intel P35 ($25 MIR)
$127 - Asus P5K LGA 775 Intel P35 Express
Oh, and I suggest getting the Q6600 from clubit.com, since they guarantee the G0 stepping. It requires less voltage so it runs cooler -- which is a good thing whether you're OC'ing or not.
$275 - Intel Core 2 Quad Q6600 G0 2.40GHz 8MB L2 LGA775 BX80562Q6600 SLACR
