Will this PSU power this setup perfectly?
Gatorade
Hi i am going to build my first computer soon and i was having a hard time picking out a PSU i saw this PSU and was wondering if it will power my first build perfectly
PSU
http://www.newegg.com/Product/Product.asp?Item=N82E16817103464
Setup
CASE
http://www.newegg.com/Product/Product.asp?Item=N82E16811119035
motherboard
http://www.newegg.com/Product/Product.asp?Item=N82E16813127197
video card
http://www.newegg.com/Product/Product.asp?Item=N82E16814129043
CPU
http://www.newegg.com/Product/Product.asp?Item=N82E16819103465
RAM
http://www.newegg.com/Product/Product.asp?Item=N82E16820145440
FDD
http://www.newegg.com/Product/Product.asp?Item=N82E16821103116
HDD
http://www.newegg.com/Product/Product.asp?Item=N82E16822148033
Monitor
http://www.newegg.com/Product/Product.asp?Item=N82E16824116282
CD/DVD ROM Drive
http://www.newegg.com/Product/Product.asp?Item=N82E16827101131
CD/DVD Burners (RW Drive)
http://www.newegg.com/Product/Product.asp?Item=N82E16827152035
speakers
http://www.newegg.com/Product/Product.asp?Item=N82E16836121118
well thats what i came up with this is my first build. I chose that RAM cause i dont plan on overclocking. for PSU i have no idea what i want and if i could get comments on that setup i would apprechiate it. Thats the PSU that someone recomeneded me so what do you guys think? :confused: :confused:
At first glance it looks ok.....however you really need to run the calculator in the how to buy sticky. And post what your budget is and what you want out of it(quiet, efficent, balls to the wall performance, modular cables, show, etc.). Not all PSU's are right for every situation and Amps in the right place over wattage.
and making someone open 12 windows, note down your config, then go to the calaculator to assist you is asking a bit much
post your config and add the extra info Spectre recommended (secondary criteria) and I'll help work up the numbers ;)
also specify fans, RAM makes little to no difference being on an inder employed rail in a midern config, but fans being in the +12V along with the CPU, PCI-E\partial AGP, and drives do
