Will this motherboard work with this memory?
lamb110
I just ordered a GIGABYTE GA-P35-DS3R from newegg and without thinking bought this memory: Crucial Ballistix 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 1066 (PC2 8500)
After it shipped I realized that I should of checked Gigabyte's website for the motherboards compatable memory. Needless to say that memory i bought wasnt on the list. Does that mean that it wont work? or will the memory run at a slower speed? A q6600 is the cpu that I will be using if it makes a difference.
Motherboard:http://www.newegg.com/Product/Product.asp?Item=N82E16813128050
Memory: http://www.newegg.com/Product/Product.asp?Item=N82E16820148069
Mine sure isn't in the support list.
and still works like a charm
It should work fine, you could have got by with a lot cheaper but /shrug.
Here is the deal, that is very high speed memory. You will not be able to set the the FSB settings high enough to fully use the rams speed (because the cpu will top out) unless you use a memory mulitplier. It is also high voltage. At worst you might have to boot the first time with just one stick and go into the M.I.T. sub menu of the bios and set the Memory Voltage to 2.2V. shutdown and then put in the second stick. Otherwise it should be fine.
Default the cpu runs at the cpu mulitplier x the FSB
Default the memory runs at the FSB x 2 (called 1:1 or on your Gigabyte a 2.0 muliplier)
Ok at default that Q6600 will run with a cpu mulit of 9 and a FSB automatically set at 266MHz 9 x 266MHz = 2.4GHz
To run your 1066MHz rated memory at full speed you will need a memory mulitplier of 1066/266 = 4.0 which you have as an option in the bios.
If you overclock by raising the FSB the memory will take some overclock but at some point you will have to reduce the memory mulitplier to keep the memory frequency at some reasonable value the sticks can handle.
Yah, what Bill said.
I have the same board and the cheaper Ballistix, but they use the same ICs, so they're basically the same sticks, lol. They'll work fine in that board, even on first boot.
If you leave the RAM on AUTO, it will auto OC it to at least DDR2-667 speeds, since the P35 chipset doesn't support DDR2-533, which is your CPU's default speed for the RAM. This should help you a bit...
/*------------- <cut n paste> -------------*/
Formulas for Intel platform @ 1:1 settings: (base FSB speed is SDR, or single data rate)
(CPU Multiplier) x [Base FSB speed] = CPU Clock speed
2 x [Base FSB speed] = RAM speed (DDR: double data rate)
4 x [Base FSB speed] = Effective FSB speed (QDR: quad data rate)
On Intel platforms, running the RAM higher than a 1:1 ratio with the CPU is, for the most part, useless, so don't bother trying to do so. If the BIOS does it for you, just let it. All you need is a 1:1 config, though. Here's some possible clock speeds (as always with OC'ing, your results will vary):
Q6600: 9 × 266 = 2.4Ghz, DDR2-533 << STOCK speeds
Q6600: 9 × 333 = 3.0Ghz, DDR2-667 << Nice OC
Q6600: 9 × 378 = 3.4Ghz, DDR2-756 << Good OC, near max for B3 stepping
Q6600: 9 × 400 = 3.6Ghz, DDR2-800 << Great OC, near max for G0 stepping
/*------------- </cut n paste> -------------*/
Thanks so much for all the advice. I cant wait for the parts to get here tomorrow.
Well I just put everything together, and it booted right up no problems. Detected both sticks, at 1066mhz so I am happy. Its installing windows right now... I cant wait to play some UT3, Bioshock, and Crysis!!!
