Swiftech Apogee Cpu block or Swiftech APOGEE GTX
Swiftech MCR220 Dual Rads
Swiftech MCP655-B maybe 2
Do I still need a reservoir.
Should I replace my rads with the Swiftech MCR220-QP-RES
Cooling a Q6600.
Thanks
1- Don't get a Apogee GTX due to the aluminium top. Get a D-Tek Fuzion instead (cheaper and much better).
2-Get one MCP655, not the B version since it's locked to 4 while the adjustable one can go up to 5. You don't really need 2 IMHO.
3-Keep the radiator but you need either a T-Line or a reservoir. I suggest you get a Swiftech MCRES, which is cheap and does the job very well. Make sure you put the reservoir/T-line before the pump.
Yep, Get a Dtek Fuzion.
You only need 1 pump, and 1 radiator.
I suggest getting a triple radiator if you EVER plan on putting your GPU in the same loop. If not, a single "double" radiator (like the MCR220 or the BIP 240) will do.
