Will this CPU cooler fit inside this case?
Outside height is 6.6 INCH about 166mm.
Front mounts a 140mm fan, back two 80mm.
There is a brace that may or may not impede cooler height.
A70 listed as 159.5 mm tall. Standoffs are about 6mm add motherboard and CPU say 10-12mm.
My guess is you want a 92mm fan cooler or a top down one.
Cooler Master GeminII S524 $43 appears about 4.1 in ~106mm tall = A50 cooler
Noctua NH-C12P SE140 $75 appears about 152mm tall when using top fan.
Almost forgot Enermax T60 coolers $45-50 depending on fan 115 mm tall with fan = A70 cooler
Note GeminII S524 has most Ram clearance and can upgrade to 140mm fan
Noctua is best cooler if it fits with two fans, does well with one
Enermax can block RAM slot
