Will this case fit two GeForce 8800GTs?
quick answer, no
Long answer, yes
You can fit two in there, however you would have to remove the dedicated graphics fan the case comes included with. That beast would free up 3 full inches and would give you all the space you need for the cards.
quick answer, no
Long answer, yes
It would fit even GTXs just fine without removing anything, actually.
yes, it can fit pretty much any graphics card out there, even the quadros that are longer than the 8800 gtxs.
