Ok heres my build. Any problems? I want to use a micro atx motherboard in a full sized atx case as you can see here. Will this work? I want to do this so that i can buy a videocard to put in once i have the money and just use onbaord til then, can i do that?
case -http://www.newegg.com/Product/Product.asp?Item=N82E16811129155
motherboard-http://www.newegg.com/Product/Product.asp?Item=N82E16813157085
whats going in:
Socket 939 AMD A64 3500+ Venice
Corsair Valueram 1gb 2x512 ddr400
80gb WD Caviar P-ATA 7200rpm
EDIT: This build is for my friend, so dont let me mess up
whats going in:
