My current system is nearing the end of it's life and after upgrades after upgrades I was thinking it would be better to just build a new system.
I have already started and have gotten myself the Coolermaster Cavalier 3 case with Window and an Enermax EG465AX-VE and some Sharkoon rounded cables.
I have been looking at the following components and was wondering if they would create a good stable machine?
CPU: Athlon64 3200 (Winchester core)
Mobo: Asrock 939Dual
RAM: Geil 1Gb PC3200 Dual Chan DDR Kit (Cas 2.5 6-3-3 with Aluminium heat spreader)
I need some advice on a cooler for the CPU as it will be OEM. There seems to be so much to choose from but I found one which seems to do a fantastic job (from reviews) and is at a very reasonable price - £16 ($28). It's the ThermalTake K8 Silent Boost Cooler (A1838). Will this fit in the mobo or will there be issues?
EDIT: Just saw another Thermal Take - Venus 12 for only a few quid more(£18.50/$32.50), is this any better?
I am currently using a Geforce 3 Ti500 and will eventually upgrade to mid-high end AGP or PCI-E. I would also continue to use my current HDs which are IDE units. I think SATA will have to wait too.
The reason I am using the Winchester core is because here in the UK I have found a large online retailer who is selling that CPU for cheaper than others and much cheaper than the Venice core. Besides I am on a budget and not really looking to spend more than £200 (~$350)
So what do you reckon? Am I missing something..
Many thanks
Many thanks
