Will these components Work Nicely?
satriani5902
I just wanted to check with you guys to make sure everything that I ordered will work together nicely. I am not looking to overclock, just a nice quiet and cool system. Thanks for the time looking over.
ASUS P5W DH DELUXE/WIFI-AP Socket T (LGA 775) Intel 975X ATX Intel Motherboard - Retail $269.99
Intel Core 2 Duo E6400 Conroe 1066MHz FSB 2M shared L2 Cache LGA 775 Processor - Retail $240.00
SAPPHIRE 100154 Radeon X1800XT $199.99
G.SKILL 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 533 (PC2 4200) System Memory - Retail $169.99
Antec Performance I P180 Silver $114.99
Antec TRUEPOWERII TPII-550 ATX12V 550W Power Supply $84.99
Seagate Barracuda 7200.10 (Perpendicular Recording) ST3250620AS 250GB 7200 RPM 16MB Cache SATA 3.0Gb/s Hard Drive - OEM $79.99
ZALMAN CNPS9500 AT 2 Ball CPU Cooling Fan/Heatsink - Retail $62.99
NEC Black 16X DVD+R 8X DVD+RW 8X DVD+R DL 16X DVD-R 6X DVD-RW 16X
$28.99
2007FPW $390
Total: $1,641.92
All looks good, but why the different burners? If they're the same price, why not simply go for two DVD burners? Might as well get maximum functionality.
To the OP.
Seems like a very reasonable build to me. Make sure you shop around and compare prices!! I build a lot of systems for myself family and friends; and I know you may be able to save up to 30% just by shopping around ( although I do live in the UK).
Also in reference to quietness, the X1800XT is not the quietest card in the world, and in that system it will easily be the loudest thing you hear.
Edit : [spelling]
