Will the real HD7950 Please STand UP?
SonDa5
Where are the real reference HD7950s at?
The vanilla ones?
Can't find 1 anywhere.
The "reference" models more or less do not exist for the 7950 series, AMD left it up to the board makers to decide that, they supplied specs, as well as the various components to be used on a "refernce" clocked model, but the reference in this case does not exist, it seems most of them decided to have a refence model that uses a fan dead center with ref components and clocks but thats as close as youre going to get.
I prefer a blower fan at the one end of the card, at least they would have the option of the fan sucking air from both sides of it, but alas, very few have been designed this way, or for that matter a fan that is still blower type but with a slight incline to draw air more smoothly rather then fighting physics, example -\ or -/ to cater to single use of card or if one has multiple cards, angle the fan and have a slight beveled edge to where it draws its air, reduces tubulence and focuses the air to get drawn in.
The HIS and PowerColor 7950 look as reference as it gets (apart from the stickers)
http://www.newegg.com/Product/Product.aspx?Item=N82E16814161400
http://www.newegg.com/Product/Product.aspx?Item=N82E16814131457
If you are looking for the cards with DHE that were sent to reviewers, those seem indeed not be sold anywhere.
The back side of the PCB isn't the same as the reference models..
Reference model pcb photos can be found here: http://www.hardocp.com/article/2012/01/30/amd_radeon_hd_7950_video_card_review/
Like I had stated, and this was more or less talked about prior to 7970 launching, the 7970 will be a 3 phase type launch, first phase=reference 2nd phase=modification 3rd phase=full blown custom.
The pcb for 7900 series, for 7800 series, and for 7700 series, AMD apprently wen to great lengths to get the VRM, memory chips, core, alignment holes etc all buttoned down at allow thier AIB to be able to customize to thier hearts content. They did this to ensure the fastest time to market, and fast turn around for ALL thier AIB not just the largest ones. to my knowledge, in regards to the 7950, no matter what the AIB do, the 7970 will be faster anyways, not like it was with the 6850 custom or 6950 custom able to match or exceed thier higher tier brothers.
7950 did have a reference model that AMD provided to some partners for them to do thier design, as well as to show places that do reviews as a "baseline" what the 7950s are and what they could do. From what I have heard and have read, the 7950s are up to the AIB to design as they so choose, the PCB for the most part is already built, there may be some slight variations, but for the most part the PCB is about the only thing AIB do not have to worry about, if they do not want to. The cooler, the shroud, pretty much everything else is up to them, use the reference "concept" to trim on costs or make a custom model to gain prestige/coin.
I tell you what, I wanted to see the reference models for thier design for the 6k series as well as the 7k series and more like the GTX cooler for the way it has the one edge by the fan that has a slight bevel to it.
I think this is the cleanest nicest looking design, nice looking, and simple, to bad I have never seen them anywhere. http://www.geek.com/articles/gadget...adeon-6800-series-of-graphics-cards-20101022/ or http://www.pcmag.com/slideshow_viewer/0,3253,l%3D262875%26a%3D260818%26po%3D4,00.asp?p=n for the beveld fan edge.
Even if they sunk the fan into the shroud a bit, to act like ducting it would improve the cooling potential and can reduce the fan speed to combat noise, by doing this, they could also put a mesh or something similar around it so it can gather air from anywhere, even if there are multiple cards stuck to each other as in CFX or SLI usage looking like so ->_\-/_<- air can flow over the top of said duct and into center of fan, or it can go through the bottom edge as needed to aid cooling or to help when the center is not getting the air it needs.
Blower fans do work very well for the high pressures they create, and quite well for the CFM, but they also create alot of noise, by helping it get the air it needs, with less RPM needed to get that air, it might help its temps/noise alot better.
Anyways, I like the reference colour, style of the 6900/6800 series coolers the best, little red swoosh through the black cooler, I have never seen any of these ANYWHERE :(
The aftermarket PCB looks better than AMD's reference, some have better electrical components and improved cooling.
I'd like to see the reference HD7950 PCBs available because they will work with HD7970s water blocks which are already available.
With different non reference PCBs on the HD7950 it may be tough for a water block builder to make a mass produced water block that can be sold for a profit. Different PCB designs cause problems for water block builders and for HD7950 owners that want to water cool.
I want to water cool and this is why I wish there was a reference HD7950 available.
a good chunk of the pcb, component selection and such is/can be reference, its just the design of the cooler and such that changed, I am sure there will be slight variations in the component placement, but the mounting holes and such shouldnt change that much, but this depends on which AIB you are talking about.
Sapphir, Powercolor, Visiontek are notorious in doing custom PCB work, shorter pcb, different component placement etc. ASUS, XFX, and MSI to some degree dont usually change the PCB much, as that entails added costs, Radeon 7k series, like I mentioned, and as far as AMD said, they left it up to the AIB to do thier own designs if they choose to do so, however, they also locked down the "reference" to reduce complexity, ensure higher stability, and to reduce costs even if the AIB decide to change this such as the cooling assembly.
