Will the 8800GTS fit?
itzhobbes
Any of you guys that own a Gigabyte P35-DS3L also own a evga 8800GTS? I ask because I want to know if this card will fit into this motherboard? Seems like theres a heatsink at the end of the PCI-E slot that might cause some issues.
Do you own a DS3L and a 8800GTS? Your sig says otherwise and I don't want to spend $300+ just to have to return it. :(
Based on the angle views I've seen of the DS3L and my own experience with Gigabyte boards (DS2R which has a similar heatsink) and my 8800GTS, I think it will fit. I never had any problems at all getting mine into place.
Well, I was basically thinking what kirbyrj was saying.
Plus, newegg has first hand accounts on their reviews of people using exactly what you're asking. :)
It will fit. The heatsink will not get in the way.
It will fit the motherboard. The only thing that I know some people have problems with their cases. If you have enough case room you are all set.
Spartus4
