will S-video carry digital audio?
DatHak512
I'm trying to get a little more awesomness out of my A-T A-900s and i was thinking about getting an external amp. my question is how do i get digital audio out of this PowerBook? i've got an S-Video port, but I don't know if those are digital or 'analog'. anyone care to enlighten me? 'preciate it.
Could you theoretically put audio through S-Video?
I mean, obviously it won't work in this case, because the Powerbook is only meant to output video to the S-Video port. But is an S-Video cable capable of audio like an RCA cable can do both?
No, as far as I know, there is no port configured to send audio through it. Of course, any pair of wires can carry audio if you want to make it do that.
It can carry just about anything you want to put over it, but, like talonz said, nothing does anything other than video over s-video. If you put audio over it then you wouldn't be able to put video over it. It doesn't really make sense to do that.
Well, it was a theoretical question. I myself don't know of any practical uses of audio over S-Video...
Maybe the S in svideo means super video:) prolly not though.
if the powerbook has a spdif port you could use that to send signal to the amp.
The physical cable and connector? Yes, it can carry any signal with some degree of success. It is indeed a basic RCA connector and coaxial cable. However, there may be impedence matching issues with certain cables. For instance, the typical coaxial S/PDIF cable for digital audio signals is universally rated at 75 ohms for impedence matching purposes. Your plain jane RCA cable, or even S-Video cable, may not make that distinction. It depends on the application, but theoretically, you could run audio through an S-video cable if you wanted to.
