will running 2 pumps increase the pump lifespan?
robphelan
i'm only going to cool my 3700 san diego & 7800 GT OC using a Danger Den CSP-MAG Pump.
my question is if I add another pump, opposite in the loop, will that increase the life span of the pumps?
could i even run them at a lower flow rate(lowering the noise) since the pressure would be more constant?
I would only do this from a WC system reliability point of view in case one of the pumps fails the other will continue. If your worried about pump life go for iwaki or ehiem, nothing else especialy ones made for PC WCing.
running two pumps in series can actually decrease the life of the CSP. The seals are not meant to withstand the pressure of one pump feeding directly into another.
Funny, I remember them (CSP) selling a kit with 2 pumps mounted to a bracket with instructions on how to plumb them together in series and parallel. I guess that's why you don't see that anymore.
i didn't mean directly from one to another... i meant opposite each other in the loop.
pump >> cpu >> gpu >> pump >> rad
or something similar to that.
this was a reason that earlier designs of the CSP pump failed. With the redesign this isn't an issue so much anymore. If you want a saftey factor just set your bios to shut down at a low threshold temp. No need to run 2x pumps for that. Only if you're concerned about a restrictive loop or something, but then you should run 2x pumps parrallel in that case......
