I'm unhappy with my system's performance when running QuickPar to verify large (15GB+) RAR archives, and also when extracting these archives. I have a 74GB Raptor as my boot drive, and a WD2500JD that I was going to use as a "junk" drive in addition to my RAID5 array.
The WD2500JD isn't as fast as the Raptor, so I was thinking another Raptor in RAID0 would probably be better than extracting from the Raptor to the WD2500JD. Plus with RAID0, you're always using both hard drives. I'd probably do a 40GB partition for Windows and all my programs (overkill, but games eat up space quickly) and partition the rest as a temp partition to do all my archive manipulation on. Space isn't an issue since I have a 900GB RAID5 array and I'll most likely stick the WD2500JD in an external enclosue for backups of my important stuff, including drive images of my boot drive, which I'll defintely do if I go with RAID0.
Something I just thought of, the "sluggishness" of my system while working with these files may be due to the fact I'm either extracting to or from my boot drive. Would having a completely seperate RAID0 array be better?
