will orthos do 2 cpu's at blend
sparks
I can't get 2 sp2004 to do blend.
I get one at 100% the other just says paging ...
then when one goes to paging the other kicks in.
if you have link to anything that will do it please let me know
sparks
You need the dual core version here:
http://sp2004.fre3.com/beta/beta2.htm
Use the Larget TTF test. Thats the true test of 100% stability.
I can run the 8k TTF test at A LOT higher OC. But the large TTF test
will show the weakness of your Northbridge and/or memory which
could cause instability for you at some point.
thanks..I was using that one but I think it had an error or something it would not do blend on 2 processors.
I dl it from your link and it ran fine
thanks again
sparks
Yup, B/C most people are limited by there Northbirdge atm. You can also use normal Prime 95 and run 2 istances and set the affintys on each to run only on 1 core.
