Will not post
fibertech
I have an Epox EP-8RDA and today it refuses to post. It is not overclocked and I reset the bios with no help, I pulled the battery for about five minutes - no help. I am going out to buy a new battery and hope that is the problem. Any suggestions? BTW the only code it is showing is "FF" which is "Boot attempt (INT 19h)"
This thing is three years old, so no RMA for me, I guess I will start looking for a new MB
Well, I just installed my new Motherboard and am getting the exact same thing. I guess I'll try a new power supply next
Well, I just installed a new power supply and pulled everything out, replacing each piece one by one to see if it changed the post code. All I get is F2, that code isn't even listed in the manual. Anybody have any idea what F2 is?This thing will not post
I even had a similiar problem yesterday, and it turns out i had my cpu fan plugged into "case fan." Motherboard had a system to shut down if the cpu fan wasnt plugged in. Took about 2 hours to realise what was going on.
I just tried this and it is still throwing F2
thanks
3 years old, Check the capacitors...some of those boards got blessed by the "Bad Cap Fairy"
...seriously...
MD
...seriously...
MD
I had four bad caps on the old one. The new one has a different brand of caps
i wouldnt be so sure that its your processor just yet. I replaced my amd 2000+ with a friends 1500+ and it still hangs in the same place. its unlikely that both processors are dead. ive also unpluged all ide hardware and even switched out my video card and ddr ram. Im clueless to what it is. only thing left is powersupply but as it seems to be getting plenty of power to run fans and harddrives and motherboard i dont see how it could be. ive also used 2 different motherboards. this just happend when i was installing omega drivers for my geforce fx and went to restart my computer and bam. now it wont post. seemed to fast for any processor because there werent previous symptoms usually associated with a dying processor. if you found out what is wrong lmk plz.
Test For Power Pin Shorts in an AMD Athlon™ Package
•With an Ohmmeter, measure the Vcc to Vss resistance of each unit according to Figure 1 for ceramic packages, and according to Figure 2 for organic packages. Use the indicated orientation of the colored probes. The black probe is Vss in both figures.
•Each digital multi-meter probe in Figures 1 and 2 is only making contact with one edge of a capacitor.
•The resistance of a good processor, between Vcc and Vss, should be > 10 ohms (“Palomino” core) and >5 ohms (“Thoroughbred” core).
•If the resistance is < 10 ohms (“Palomino” core) and < 5 ohms (“Thoroughbred” core), the processor should be considered as shorted. DO NOT INSERT A SHORTED PROCESSOR INTO A MOTHERBOARD.
