Will my XP3200+ Work on this MoBo?
r1skh
Hi, I have another newbie question for you guys
I have the ABIT KX7-333 (SOCKET A) motherboard (currently running XP2200+ CPU), specs of MOBO are here:
http://www.abit-usa.com/products/mb/techspec.php?categories=1&model=31
I have an Athlon XP 3200+ CPU that I got recently, will this work in this motherboard? Im just confused because the ABIT specs show it only supports CPU up to the XP 2600+, but when looking at newegg's spec on the XP 3200+, it says it is ok for Socket A motherboards. Here is the spec from newegg on the 3200+:
Model: AMD Athlon XP 3200+
Core: Barton
Operating Frequency: 2.2GHz
FSB: 400MHz
Cache: L1/64K+64K; L2/512K
Voltage: 1.65V
Process: 0.13Micron
Socket: Socket A
Multimedia Instruction: MMX, SSE, 3DNOW!, 3DNOW!+
Packaging: Retail Box (Heatsink and Fan included)
Model#: AXDA3200BOX
So will the 3200+ work in my KX7-333? Thanks for any help.
It looks like that board only supports up to a 166 mhz bus (333mhz) and that chip is a 200 (400)mhz bus
That board is based on the KT333 chipset. You need one based on the KT400 (or nForce 2) to achieve a 200mhz bus speed.
Why don't we clarify this...The 3200+ will work on that board, it will just not work at it's rated speed...Essentially you will be UNDER-clocking the cpu...
Later
MD
KT400 or KT400A will NOT work with the 3200+ at rated speeds.
The only chipsets available that will "officially" work are the KT600, nForce2 400 and nForce2 Ultra 400 (the original nForce2, the nForce2 SPP, does not officially support a 400 fsb, but generally will operate properly). Note that the nForce2 IGP (integrated graphics) does NOT "officially" support the 400fsb (although it usually can without issue)
