DarkenReaper57
- Oct 2, 2003
Ok, i have the 77' bonneville (sp?) core that I'm going to externally mount on the top of my case. It will face down and I'm going to drill holes to plumb tubing through the case, instead of going around.
Now, there is a distance of 17'' from the top of the case to the bottom. This distance will probably be reduced to just over a foot once the pump is there. Will the system perform well even though I intend on shooting tubing straight up from the pump to the core (appx. foot)? The eheim 1250 has a max head of 6.5 ft, and I am reasonably sure that this is sufficient, but I just wanted to confirm this before I set everything up and start cutting.
Maybe I would be better off placing the pump a bit higher up, such as in the optical drive bays? I dont like this Idea, however, because it would be difficult to set up as I am using 2 of 4 bays already. I'd rather not place the pump external either.
BTW, here is my complete setup:
d-tek white water CPU block
d-tek GPU block
eheim 1250
cylindrical res
77' bonneville heater core
2 120mm fans + shroud for core
Thanks for the input.
d-tek GPU block
eheim 1250
cylindrical res
