Falling Anvil
- Nov 3, 2007
Ok, so I'm in the market for a new video card at this time, looking at either an HD 4870, GTX 280, or maybe a 260(not very likely with the rumored extra shader card coming out soon, maybe). Problem is, I don't know if my CPU, an E6550 @ stock, is going to bottleneck these cards. Before anyone says to overclock it, it's a Dell with it's guts moved to another case so I can't overclock unfortunately, and getting to a motherboard that can probably wouldn't be worth it to me in terms of cost and effort. I've got two gigs of ram currently and looking to go up to four so I don't think ram will be an issue, and a Corsair 550VX that'll probably be able to power anything under a 4870x2 so that should be ok. Only the CPU is holding me back.
Ya think I can get by with it.?
(Before you ask, yes I do feel kinda silly asking if a 6-series C2D will bottleneck anything. )
