will mini-itx boards play games?
thebro
will mini-itx boards play games very well? i was thinking about getting a mini-itx and a good pci video card. now is the cpu fast enough to play ut2k4. i was looking at the 800MHz and higher ones.
The VIA boards won't handle that very well. However, if you go for a shuttle box or something like that, it will work just as well as a normal computer.
Originally posted by thebro
damn... you sure?
Considering the VIA 800 Mhz is probably on par with a P3 500, it should be quite obvious that it won't play those games. Go look at Ut2004's minimum and recommended specs, and then look at the Via boards again.
