I have a PC with
- 3570k CPU
- two 24" monitors.
-I use the GPU on the motherboard
It works OK, could be faster for Lightroom CC/Lightroom 6. This PC is mostly used for photo editing and I frequently edit well over 1000 RAW images per set.
I have a Geforce GT 440 1GB DDR3 PCI-E that I can use (free). Will I notice any significant improvement with the above configuration? The Geforce is only about 15% more power than the built in GPU, but my thought is it would free up the CPU which may make a difference.
I'm very short on time so only want to try it if it might help.
Right now with Lightroom it gets bogged down when editing (crop, changing color temp, etc.) Importing is OK.
Also, I have an aftermarket CPU cooler with 120mm fan. Should I try conservative overclocking?
- 3570k CPU
- two 24" monitors.
