Will it fit?
Hi gang. I bought an NZXT vulcan luggable case (for LAN parties of course) to house my m-ATX setup. The components I have I know will fit, well, all except for the power supply.
I'm sporting an Antec Truepower 1000w from 2009. It's been reliable for me but it is quite long. I've looked up the length of the PS and the max length posted by the case and well, they are apparently identical. I expect to have a cable management headache, which I'll work through, but does anyone have a NZXT Vulcan and Antec Truepower 1000w setup? Although the lengths posted are the same, it'll be a VERY tight fit, if it'll go at all.
Just planning if I'd need to buy a new PS or not, hoping someone has this setup and can share experience / lemme know if it'll fit.
Tx in advance!
Nevermind. Probably a non-issue now. My apparent lack of research has resulted in me not realizing that my corsair H50 water cooler can't be mounted on the top or rear fans very well, so I need to mount it at the bottom front, which involves removing the lower drive cage, which would give ample room for the PSU.
Thankfully, I don't need the drive cage, the upper cages will handle my drive setup.
