Will It Fit?
Lancid
Does anyone know if the Cooler Master Hyper 212 Plus will fit inside the sugo sg02?
Or just the amount of space in the sg02 for an hsf?
I have the 212, so can measure it (it's about exactly 150mm/six inches tall).
EDIT: Seems clearance is only 78mm? Can anyone confirm?
It won't fit. The SG02 requires low profile fan, maybe something like Scythe Shuriken or the stock Intel fan. Definitely not the 212+ because the power supply hangs way too low.
