Will it fit ???
Dunno, measure it out. If you don't already have the card, you can easily find its dimensions on the web.
It should probably fit. The card is about 9 inches long, so I really doubt it would have any issues fitting (you could always look up the clearance in that case or measure it yourself to double-check).
Will it blend?
:D
Looking at the inside view of that case it would normally accept a full ATX board. That board is 9.6 inches wide from the back of the case. The hard drive bays are set back a little from that I it looks like you could even get a 10.5in long card like a 9800GX2 or 4870x2 into that chassis.
Thanks guys. I just sold that video card and the guy said he wasn't sure it was going to fit in his case when he picked it up. I had sent him pictures of it but he's more newb than me ! He couldn't remember the exact name of his case but he was sure it was an Antec and it came with a 380W power supply.
