Will it fit ...... before I make an order
tmaxxking1
In a few days I need to order a card for a friend
We built his system in this HP case
http://h10025.www1.hp.com/ewfrf/wc/...gory&cc=ca&dlc=en&lc=en&product=4041202#N1060
Still a toss up between both of these cards ..
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130679
http://www.newegg.com/Product/Produ...17075X740592Xa71030273330b3e31b8a5007eb2e85a6
right now his rig has an Athlon X4 630 8 gigs Corsair 400W
the screen is running at 1366 x 768
wow cataclysm will be the main game being played
Yes, either of those cards will fit inside that case. The 6770 is a little shorter, so it'll be an easier fit and it's slightly more powerful than the 450. Just make sure you have a 6 pin PCIe connector available (the CX400 does, but I don't know exactly which PSU you have), or enough amperage to support a dual molex to 6 pin adapter. You'll probably be ok with that 400w, but the suggested PSU is 450. If you experience erratic shutdowns, blinks offs, or random restarts, then you know it's time to get a more meaty PSU.
**Source - I'm a BB Geek Squad Agent, I see those cases all day long.**
If he is a BB Geek Squad agent you might want to get a second opinion! :) them guy's don't much of anything!
lol, that's actually why I took the job. It's the easiest way for me to shine and look good when promotions become available :)
That's what she....Oh, yeah it will fit....:p
