5770's CF even with the 5770 memory is 128 bit and DX11.. I'm apologize if I'm beating a dead horse. I did a search on the forums and came up with a few things but nothing I could use to make my decision on.
Asus M3A79-T-Deluxe
4GB OCZ Reaper 1066
PII x 4 3.2
21.5" Asus running @ 1920 x 1080
Also would love to get a 5970 but I'm a old, cheap and think 600 is a little high for a video card.. and the 5870's are high IMHO..
Hmm, I really don't see a need for you to upgrade as your 2x 4870s will be maxing that setup. In fact if you went any higher end your CPU would be bottlenecking your video cards at that point.
Framerate-wise you wouldn't notice the difference between 2x 4870 and 2x 5770 but you'd get DX11 and the ability to add a 3rd monitor for Eyefinity. That's about it. So in your case, there's not a strong reason to upgrade unless you're doing your whole system as well.
Not at this point.. I think I will snag two 5770 to CF in my kids machine... they are running a 8800GTX
Sounds like a good plan and your kid is getting a pretty big upgrade there. This is going to sound obvious but make sure his mobo supports crossfire.
Asus M3A79-T-Deluxe
4GB OCZ Reaper 1066
PII x 4 3.2
