Will it all fit?
Thanatos.
ok im wondering if a XP-120 with a Asus A8N-SLi Deluxe will fit no problems in a centurion 5 case?
Are you referring to the depth of your case, since the XP-120 fits on your board> the board is ATX spec>fits in the case>so are you referring to depth? Look-up the specs for the case. Though the XP-120 isn't a height issue, so??
gl :)
you have very precise question... if I had Asus A8N-SLi Deluxe with XP-120 in Centurion case I would answer that... but I don't...
the reason i ask is i saw a pic of a Gigabyte GA-7VM400M M-ATX with a Scythe Samurai HSF heatsink and it was pretty tight here is what im talking about
if its that tight of a fit for a socket A im worried about fitting a xp120
EDIT: oh nevermind i just found a pic it should fit ok
