RM_Bulldog
- Jan 12, 2003
i fried my Mb and im replacing with the exact same MB will i still have to reformat? or will it be all good
If its the same motherboard (which he indicated in the original post) he should not have to reload any drivers, thus leaving no "ghost drivers." Similarly, Windows will have no qualms with the new motherboard.RubberduckY said:I would say that you might want to format. This is becauseif you don't you will not only have to install new drivers for your mobo (northbridge, southbridge, ect...), but you will also have tons of ghost drivers installed in the background. Ghost drivers are drivers for previously installed hardware that are still present even if the hardware isn't. They run in the back ground and use system resources.
I'm sorry, I guess I don't understand why WinXP would reload new drivers in different registry keys. If you don't mind, can you please explain this to me? Or point me in a direction that will allow me to research this?DougLite said:Windows will still reload all of the mobo drivers when the replacement arrives. Granted, they will be the same drivers, but in different registry keys, leaving the ghost driver problem. A repair install of XP is another option, but backup before you try anything. Reformat is by far the best in the long run, but takes more time up front.
