Will i have issues swapping mobo's?
NathanP2007
So i have the PC in my sig obviously up and running along with a secondary PC at my desk. I am selling some parts from my secondary PC and the Mobo from my Gaming Rig, and want to use the secondaries motherboard as my primary. The secondary is LGA-775 as well, and has a better motherboard. Basically i want to swap motherboards.
Correct me if im wrong. But how i would do it is:
My secondary (at my desk) PC is a HAF-922 with ASUS mobo inside.
My gaming rig (in sig) is my HAF 932 with Gigabyte mobo inside.
I want to remove everything from the HAF 922, except the ASUS motherboard. I then want to remove everything from the HAF 932, and put it on the ASUS motherboard.
Will i run into any issues? Is there a flaw im not seeing?
(If it matters, both Mobo's currently are running Windows 7, both are LGA 775)
UPDATED: Current Questions still unanswered:
First, is the image you save (clone of the drive) , is it the same size as whats filling your HDD? 419Gb of my 640Gb drive is in used, does that mean the image will be that size as well?
Is it redundant to find and put in a safe place game saves, considering i will be saving a image of the whole drive, game saves included?
I have a second internal HDD (1Tb), that doesnt need to be image copied/clonded right? It doesnt have the OS installed so theres no reason for it to have issues when plugged into the new mobo correct? Its just a HDD full of movies and music.
Lastly, where is the Windows 7 image utility? I tried typing windows disc imager into the Start>search box but it didnt find anything.
different mobo you will be reinstalling/reactivating windows too
I highly doubt you would have any issues swapping motherboards.
i did it with windows 7 i went from a Asrock P55 to a Asus M III back to a Asrock P55 and i dont have any problems so i dont think you will
Shot in the dark. I've seen everything from perfect swap with zero issues and no reactivation, to catastrophic failure with complete loss of data and required reinstall.
If you can, make a disc image before you do it, so that if shit hits the fan you can put things back the way they were and reimage so that you have zero loss in data.
Thank you all. Very reassuring.
Mhenley: I definitely agree with that logic. I however have not cloned/made a disc image before. In a diff thread though it was brought up and people recommended the windows 7 disc imager that comes with 7, and a free one on Western Digitals site called Acronis. Do you have a recommendation or a fav? Along side the Windows 7 Image Backup, does it tell you how to use it when you do lose all your data on a Hard drive? Like how to restore that clone to a HDD? Thanks :)
I used the one built inside of Windows 7 for the longest time. You make the image and save it to an internal hard drive. In that utility you will also make a rescue CD that you boot from if you need to perform recovery, repair and reimage functions.
Nowadays, I use Acronis because I have migrated to using a 3TB USB drive, and Windows wasn't able to write to the USB drive without issues, but Acronis can. Either of those options for your situation will be fine.
Swapped-out an Asus P6T Deluxe V1 with an Asus x58 Sabertooth one week ago. Prior to doing the physical swap I uninstalled the audio, video, NIC and disabled Avast! anti-virus. Went smooth as silk. Had to activate Windows 7 Ultimate x64 again but that wasn't a big deal at all. Took less than 15 seconds.
I was able to get away without reinstalling my oem copy of windows xp when swapping mobos during a huge upgrade. that said, crack your windows activation now rather than later. you're legit, but windows will give you absolute hell when you go to swap. for me, they expected it to activate online, but my ethernet drivers weren't loaded. umm yeah, that didn't go over too well. calling the phone service got me nothing. if you're legit, save yourself the hassle and just turn that crap off.
1: Yes, the image is the exact and complete contents of the entire partition.
2: Yes, it's redundant
3: No, no issues at all, do not clone/image this drive unless you want to later on as a full system backup solution. If there is enough space on that 1TB then you can use it to hold the 419GB image.
4: Control Panel -> Backup & Restore
Thanks. So i have started the Imaging of my C disk on my Gaming PC. When confirming my backup settings, it showed "The following drives will be backed up": (C:) (System). Which is what i want so i hit start.
However on the HAF 922 (Desk PC) it shows both the (C:) (System) and a "System reserved (System)". Do you have a clue why/what the System reserved system is?
(Idk if this is why but just so you have all the info. This PC used to dual boot windows and Ubuntu on a 80Gb HDD. However i had issues when installing Win7 SP1 so i changed the boot priority so it boots directly into windows, and i had to repair my windows so the master boot was on it if i remember correctly.)
If you have the drive partitioned already when you install Win7 then it uses the partition available, but if you have the drive unpartitioned then it will make a system reserved partition and then a primary partition. It's annoying, to say the least.
Either way, it sounds like you've done it right.
Well, physically changing the motherboards took hours. But once i turned on the computer, everything was perfect. A huge long list of things (drivers etc) installed instantly, i installed the latest AMD driver, and i clicked "activate my windows" and it did it online for me , took 3 seconds and bam my windows was genuinely activated.
Thanks for all your help guys.
Now as far as the Image's i created are concerned. I get that its smart to have one at all times so if your OS hard drive dies (or something) then you have your whole OS backed up. I was just curious, do you have to burn a disc everytime you create a image? Or as long as if i create a new image in the same place as where the old image was, the disc i made still works?
You only have to burn the recovery disc one time. Image location doesn't matter, as you can browse the hard drive for the location.
Glad to hear it all went well, and +1 for now having a backup which can save you hours of frustration, if you keep it up to date. My suggestion is to set it to get yourself a more permanant solution for keeping drive images (2TB green/eco drives are cheap these days) and set a schedule to perform a full backup at least once a week. All it takes is one failure, and you'll be glad you did. Cheers!
Sweet thats awesome. I would have done imaging of my HDD's a long time ago if i had known it was this easy. Yeah the buying a 2TB green drive definitely sounds like the way to go. I do have a 2TB NAS Seagate Hard drive, but i dont back up to it with confidence because i had one for about 6-12 months and it failed so i am on my second now. By set a schedule, is there a setting so it will be automated once a week (or day or month or w/e you want) or did you mean i should personally remember to do it once a week?
Im guessing by the sales that this is the favorite when it comes to green 2TB drives? http://www.newegg.com/Product/Product.aspx?Item=N82E16822136514 )
Smartest idea.
That's the drive I have, very popular, very dependable.
I can't recall if Windows has the option to backup on a schedule, I believe it does. I know Acronis does. I recommend setting a day of the week (and a time you don't use the computer) to perform the backup automatically. It's too easy to forget, and when you remember, sometimes it's too late.
Ok so i have gotten my 2TB green drive and have setup the windows automated backup. My issue now is:
There are two things you can backup. You can backup a system image (which i want) and "Data File" backup, which im not totally sure what it is backing up, and if there is a reason to backup those "data files" because i already have a system image, why backup files if i got a image of the whole C: drive?
