Hello, I recently bought a computer from Hewlett-Packard, the model is a6000n.
It has the following specs:
PSU: OEM 300W*
Processor: Athlon 64 X2 (W) 4200+ 2.2 GHz
Chipset: GeForce 6150SE nForce 430
Motherboard Name: ASUS M2N68-LA
Memory: 1GB DDR2**
HDD: 250 GB SATA 3G 7200rpm
Optical Disc Drive: 16X DVD(+/-)R/RW RAM (+/-)R DL LightScribe
Modem: 56K bps Data/Fax Modem***
Video: NVIDIA Integrated 6150SE****
Audio: High Definition 7.1 audio
Network: Integrated 10/100 Base-T Networking Interface + PCI Wireless Card
* I replaced the OEM PSU with a Antec Basiq 500W Power Supply:
Dual +12V: Yes
Fans: 1
Input Current: 8A
Input Frequency Range: 47 - 63 Hz
Input Voltage: 100 - 240 V
Main Connector: 20+4Pin
Modular Cabling Support: No
PCI-E Connectors: 1 x 6Pin
PFC: Active
SLI Support: No
Pictures Courtesy of NewEgg.com
**Then I upgraded my memory from 1GB to 4GB DDR2 (4 Modules)
***I plan on taking this one out since I don't need it.
****I want to replace this with a high end video card (i.e. 2900xt)
I used the PSU Calculator that I found being posted here in the forums and with a 2900xt (If ever) I'll be at 480.
Sincerely,
P4rD0nM3
PSU: OEM 300W*
Memory: 1GB DDR2**
Dual +12V: Yes
Fans: 1
Input Current: 8A
PFC: Active
SLI Support: No
Sincerely,
P4rD0nM3
