senorcarne
- May 17, 2007
Ok, I have Windows Vista Home Premium but had a problem and instead decided to use Windows XP Professional. I missed media center so I hacked my professional into Media center through the common methods online (basically change a registry key and install Media Center, Pre-Rollup 2, and Rollup 2) while it still uses your XP Pro license key.
There are some things I love about XP - driver support is much better in XP and some things work better. But I see no performance gains over Vista despite what everyone says, and my games that are DX10 don't look as good in XP (obviously, because it's missing DX10).
Now, I was thinking of upgrading to my Vista Home Premium and probably will if you can answer these questions:
1) Home Premium can't install over XP Pro. But since the computer thinks its Media Center Edition, would the install work?
2) I spent a few days perfecting my XP install. It has all my games, all completely updated, as well as all my programs. Would an upgrade to Vista keep these things or would I need to reinstall?
3) A continuation of 2, will Vista be slow because it has XP installed under it, or would it be as fast as a clean install?
Also, I had Vista 64, but I would be upgrading to Vista 32. I have 2 GB of RAM. Do you think I should, or just keep a perfect install of XP?
Thanks!
Thanks!
