One product, one scenario does not make it a general rule.HDMI has already replaced DVI. ATI cards have HDMI port and my latest LCD has no DVI port and HDMI instead. This monitor has speakers inside it too so get audio straight over HDMI to it from the ATI 5870. Speakers inside LCD are crap but it does have audio out to connect to better speakers and also has a headphone jack.
I listed two products and not one. ATI makes far more than more than one product too and they all have HDMI. Does display port do sound over it's cable like HDMI? If not then obviously HDMI is the new standard and not display port.
There are always 2 standards. Consumer electronics and computing.
CE: Composite -> S-Video -> Component -> HDMI
Computing: VGA -> DVI -> DisplayPort
I would live to direct you to a previous post.
HDMI is DVI with audio, as stated. This makes it a good one-cable solution to everybody with a home theatre. For people driving 30" monitors, there is not enough bandwidth to drive that many pixels. Thus HDMI is an unacceptable standard in the computing world.
While I agree with what you are saying in principle, it is still false.
http://en.wikipedia.org/wiki/List_of_device_bandwidths#Digital_video_interconnects
linked Wiki page said:This connector (21.2 mm × 4.45 mm) has 29 pins and can carry double the video bandwidth of Type A, for use with very high-resolution future displays such as WQUXGA (3840×2400). Type B is electrically compatible with dual-link DVI-D, but has not yet been used in any products.
Grentz said:I think they should just eventually migrate everything to HDMI. DisplayPort is mostly pointless IMO at this point as it does not bring anything to the table. I still like DVI on my monitors, and still have no reason to use anything different cause even if HDMI does completely take over, you can always use passive adapters to go to DVI no problem with no loss.
DVI was fine before, HDMI brought audio integration and slightly higher bandwidth, what does DisplayPort do? I have heard of the future things it can do, and a few nice things for manufactures, but as end consumers it is really no difference at this point.
My fear will be that when they do add the cooler things to Display port it will be a newer revision anyways, so no need to invest in it now.
One other thing I forgot to mention that I like about DVI...the connector is a lot more robust. Yes, a bit bulkier, but the connectors on the boards are much more solid in my experience than HDMI which is smaller and more fragile. Not a big issue for consumers, but in more commercial applications I can see it being an issue.
Wikipedia.com said:Advantages over DVI
1. Slimmer cables and a much smaller connector that doesn't require thumbscrews. Connector pins don't run the risk of bending if improperly handled.
2. In low-light conditions or awkward under-desk connections, the DisplayPort connector is easier to connect when guided only by touch.
3. Based on micro-packet protocol.
* Allows easy expansion of the standard
* Allows multiple video streams over single physical connection (in a future version)
4. Designed to support internal chip-to-chip communication
* Can drive display panels directly, eliminating scaling and control circuits and allowing for cheaper and slimmer displays
* Aimed to replace internal LVDS links in notebook panels with a unified link interface
* Compatible with low-voltage signalling used with 45 nm CMOS fabrication
5. Supports both RGB and YCbCr encoding formats
6. Auxiliary channel can be used for low bandwidth data such as touch-panel data.
7. Fewer lanes with embedded clock reduce RFI.
DVI can carry audio as well. [SL-]DVI and HDMI only differ by one pin: the CEC bus in HDMI. Of course HDMI is always single link, so we will have to wait to see if 2560x monitors are ever driven by HDMI.
What does it actually mean that DisplayPort can directly drive an LCD? What is different about DVI such that it couldn't be equally capable of direct drive, with an LCD panel designed to accept it?
Wouldn't it have to mean that a DisplayPort direct-drive-compatible video card would need detailed knowledge of all the tics and quirks of every conceivable LCD in existence, so that it could do things like "pixel-walk" inversion, overdriving, etc? And doesn't it mean that if a new display technology came out that had its own new quirks, the older video cards wouldn't be able to drive it directly?
Or does it mean that each display would be able to upload some firmware to the video card connected to it, in some universal byte code, so that the video card could implement all of the oddities involved in driving that particular display directly?
Elledan, I found that article and it didn't answer my questions. :-\
What I don't understand is, if all that DisplayPort's so-called "direct-drive" is doing is allowing the LCD to avoid the work of scaling, what makes it any different than DVI LCDs (such as 30" ones) that have no scalar and virtually zero input lag? It makes it seem like a design choice for LCDs having nothing to do with the choice between DisplayPort and DVI.
It's quite possible that nobody knows this besides the engineers who've worked on it. Certainly nothing I've read about it so far has included any non-vague information.
Bad example. BTX had worse thermal performance, worse layout (fails for multi-socket, fails for on-die MCU) and general worse characteristics than ATX. It didn't have any convincing features other than to serve for Intel as a desperate attempt to save face with their Netburst debacle. There is absolutely no surprise that it died in a blaze of anonymity.To make an example, Intel announce BTX standard to replace ATX like 8~9 years ago. It has better colling and lower noise.
To make an example, Intel announce BTX standard to replace ATX like 8~9 years ago. It has better colling and lower noise. But motherboard manufactures do not want to participate to replace the design.
One reason why I'd love to see DP wipe the floor with HDMI is due to the poor cable and connector quality of the latter. When my housemate got a new HDTV he went through three HDMI cables before he found one which didn't cause issues with HDCP crapping out at random because either side didn't respond within time or so. Ultimately the cheapest, 5 Euro HDMI cable worked unlike the two much more expensive ones. HDMI/HDCP handshake response is poorly defined in the specification, as are the connector types, which have a tendency to remove themselves from the port they're connected to.
In comparison the DP spec is far more clear on these important things leading to far less of such most annoying issues. With the differences between HDMI 1.2/.3/.4 there are a lot of compatibility issues as well, not to mention one has to get the right HDMI cable for each standard and feature set one uses. It's downright infuriating at times.
Your statements about needing cables for different specs are not true. Certain cables are certified for certain specs yes, but in reality most HDMI cables will work with all the specs just fine. The more important thing is the gauge of the wire depending on how far you are running it.
Wait, so you're saying that there aren't HDMI cables with/without Ethernet wire? Did I just dream that all up?
You heard lies. It was noisier. This was intel's attempt to cover up for their over heating processor roadmap.To make an example, Intel announce BTX standard to replace ATX like 8~9 years ago. It has better colling and lower noise.
