I have DFI P35 motherboard with 6 intel sata ports.
I also have Highpoint 2640x4 sas/sata 4-port raid card in there.
If i put Areca 1260 in there will they play nice together, all 3 in same motherboard??
I have a Highpoint 4320 and an Areca 1231ML in the same P6T Deluxe (X58 chipset) along with a Radeon 5970, and they all work together, plus I can use the Intel RAID as well. All raid cards support INT13 and show up in the bios HDD boot selector.
However, I had issues trying to get a Highpoint 2314 card to work with other raid cards, and my Gigabyte X48 board tended to run into the Not Enough Option ROM problem, so it's hard to tell unless you actually test it out. Also if I recall P35 has less PCI-e lanes than the X38/X48 chipset so it may not work or only w/ reduced performance. Bottom line you have to test out the particular configuration you want.
