TroyTalksNoMore
- Jun 10, 2004
Can I make an image of my old HD OS partitions & run them as VM's?
Long story short - while cleaning my CPU & heatsink - I bent the mobo pins.
- I had to replace it, but could not get the same mobo.
I bought a "similar" mobo, new HD & installed WIN7-64
I'd like to just boot the old HD OS's via dual / multi-boot menu...
Will my old HD & OS's work on my new P45 mobo?
- current BIOS is set to boot from new HD only...
- I was going to pull the cable off my new HD, or set old HD as boot via BIOS & try it.
My old HD was 1TB - split like this:
1/4 = XP OS
1/4 - WIN7-64 OS
1/2 = DATA
I slaved my old HD & copied my data to external drives.
However, I still want to run my old HD - because it is loaded w/ software & games!
Old mobo - GIGABYTE GA-EP45-UD3P LGA 775 Intel P45
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128358
New mobo - GIGABYTE GA-P45T-ES3G LGA 775 Intel P45
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128496
Any help is appreciated!
1/4 = XP OS
1/4 - WIN7-64 OS
1/2 = DATA
