will adding memory speed up my computer?
TigerUpperCut7
My laptop is a bit slow right now. It's a lenovo t60 1.66 ghz with 768 MB ram.
Do you think adding more memory will speed it up? I don't really use many programs, don't game, and defrag and clean up the comp regularly. It's just that bootup takes a long while, clicking the start menu takes time to load occasionally, the real basic stuff. I have ram booster and it says 250mb ram free and I have only firefox open right now.
Any ideas?
Thanks
probably, but yrmv. windows will always use a portion of your swap file, even if you have ram free.
I'd recommend optimizing your startup routine with msconfig and clearing out your system tray/active programs as well.
Well first of all uninstall ram booster or whatever "memory management" software you have. Windows hasn't needed one of those since Windows 98/ME (may it burn in OS hell)... It can't be possibly more efficient at managing the memory than the OS itself.
I have a R52 myself and it boots up slowly because of the 5400 rpm drive and the tons of stuff I've put in it. 768MB is getting pretty close to minimal though, I would say buy a 1GB stick from a store and try it, if it doesn't make a difference return it (yeah yeah its immoral blah blah). If it does you can get one of those online for $20 now...
Yeah, sounds like you're in need of the old format and reinstall more than anything. Even defragging and "cleaning" (cccleaner is the /only/ cleaning prog. I'd trust, and all it does it delete files I'm too lazy to go to the directories to get myself) can only do so much.
Reformat, reinstall, get all your drivers up to date, run Windows Update a few times, and image the drive with Ghost or similar... then never have to do it again. I love me some Ghost.
