Will adding a 256 stick help my POS dell
Shakezilla
I have a POS dell 256ram integrated video blah blah blah. I play CS:1.6 I was owndering if adding a cheap 256 stick would help me in these areas.
Alt+tabbing back to windows: speed this up
More Fps
Less Lag when a lot of people are around
Switching maps on server speed
Turning demos into movies
Thanks a lot for any help.
Adding that much ram will help your system in just about everything you do.
Enjoy the speed increase.
Yeah, that should help, upgrading the video would help alot to. You can get a Radeon 9200 PCI pretty cheap. I think the Video card would be a better upgrade over the memory though.
edit I thought U said a agp card at first cleric.
I will look into the pci card.
Yeah I think I will pick up a 30 dollar stick of 256 tomorrow from the egg. Hopefull its wotrth it.
Anyone else think that card over the memory?
I assumed since it was a POS dell (My parents bought one for their home office, nothing but problems) it only had 2 PCI ports or something like that.
If it has an AGP port, use it.
I saw on NewEgg a Geforce FX 5700LE PCI, anyone know if that is any good?
That 9200 is too pricy for this comp lol
Its the family comp and I just want it to be useable 100 bucks aint worth it. Even if I have to wait 4 months to build my own I dont wana sink 100 into this POS. I tihnk the ram will be the better but for cost
Mushkin 184 Pin 256MB DDR PC-3200 Basic Green - Retail $31.26
SAPPHIRE ATI RADEON 9200SE Video Card, 128MB DDR, 64-Bit, DVI/TV-Out, PCI, Model "100565L" -Retail $53.00
Comes to $84.26 Not bad for an upgrade like that. But yeah the memory would give you an all around performance boost, upgrading the video card would make your games look nicer.
I like that mushkin ram for cheap. A nix on the vid card tho. Im not willing to spend that much.
I can pull 100 fps if i want :p but than I get in game lag.
Muwhahaha 100fps with this pos
I set max fps to 60 and its a good balance.
