icehokplyr
- Oct 9, 2004
Will a Zalman Heat sink fit on a A8V board??
Thanks in advance
Thanks in advance
Nom Anor said:the CNPS7000B-Cu
will it fit ?
Nom Anor said:these guys have it: http://www.quietpcusa.com/
But i'm thinking of getting an XP-120 with a Panaflow fan.
A guy who has the same setup like me says his CPU is 41C idle and 46C under load (using XP-120 cooling).
btw, thanks for the help icehokplyr.
kubalaTF said:Thanks for giving me the place that sells them. I got to ask though, is the diffrence between 7000A and 7000B worth $10?
