Will a shuttle support athlon 64?
NUNCA
Will the
Shuttle XPC Barebone System for Socket A at 400MHz FSB AMD CPU, Model SN45GV2
support athlon 64 3000+?
Quoted from newegg specs on that particular Shuttle:
CPU Support: AMD Athlon XP / Duron Socket A with 200/266/333/400MHz FSB
So that's a no. The A64 3000+ comes in various flavors anyway. Is the one you have or plan on buying a socket 939 or a socket 754?
Look at the specs of the processor you want, then look at the specs of the Shuttle system. That's all you have to do, really.
EDIT:
Browsing through Newegg, what you're looking for is either:
---Socket 754
Shuttle XPC Barebone System for Socket 754 AMD Athlon 64 CPU, Model SK83G
Shuttle XPC Barebone System for Socket 754 AMD Athlon 64 CPU, Model SN85G4V2
---Socket 939
Shuttle XPC Black Barebone System for Socket 939 AMD Athlon 64 CPU, Model SN95G5
If youre talking about a shuttle that has the case and looks like the SN45GV2 but supports A64 - youre also out of luck since shuttle doesnt let you mix and match cases with motherboards - although that would be nice. That having been said, I think the SN95G5 looks AWESOME. You could get a socket 939 3000+ to go with that.
if your asking if a socket A motherboard will support a socket 754 processor then the answer is no.
