Will a Laing 12v Pump be enough for.....
Will a Danderden (Laing) 12v Pump be enough for a Thermochill 120.3, TDX, DD 6800 Block ? there will be no resevoir, just a T-Line.
pump<radiator< TDX<6800<T-line
The Laing pump is about the best water cooling pump on the market at this time. It has great flow, super head and a MTBF rate that can't be beat. To top it all off, it's 12v and runs cooler than 110vAC pumps.
I've got the noisy model also, but I don't find it all that bad. I can't really hear it over my 2 120mm panaflos, but my external case is under my desk. It makes sort of a whiny sound. It doesn't vibrate at all. They have changed the new version so it's not near as loud, but it only has 317 GPM flow compared to the old one with 370 GPH.
bellevegasj said:
flak, how bad is the noise? have you tried remounting it?
I can hear it above my my fan. I doubt remounting it would do any good. It's noisy when I hold it in my hand.
