Will a kt400 actually do 400fsb?
Griffen
My old board is an epox 8k9a kt400. I know that officially the chipset only supports a 333mhz fsb. However where do these boards usually max out? Also if the board was stable at 400mhz would that push all other components too far out of spec? I'm pretty sure it has no dividers.
Schro
Dividers exist in this chipset. The biggest one being 1/5.
Thus, if you run a 200fsb, you will have a 40mhz pci bus, and a b0rk3d copy of windows within 5 minutes.
