will a 6600gt work on my system?
doug_7506
2.4 ghz processor 1 gig rdram over 160 gig harddrive
mother board specs
the card i plan on buying is a XFX 6600GT
will this work on my system? im a little worried cuz it says 4x on cpuz is that b/c of my old card a 4x or will it only support a 4x card????
It's backwards compatible but I think you need to check because you have AGP 2.0 and that one will be 3.0...I've heard ( no experience ) that they sometimes won't work if the card isn't capable of running at that voltage...
It will work fine, but i'd make sure and look at the motherboard to see if there is a physical AGP slot though. You shouldn't have any problems and the performance should be pretty good over the onboard or whatever you have. Is that a 2.4C or B?
It should work. Look here.
System Requirements
Pentium® III/4/Celeron™ or AMD® Athlon®/Duron® AGP 2.0 or later AGP slot 128MB of system memory Installation software requires CD-ROM drive minimum 300W system power supply An available hard disk drive power dongle (smaller floppy disk drive connector is not sufficient). DVD playback requires DVD drive Recommended Pentium® 4 or AMD® Athlon® XP AGP 3.0 Slot
alright so it looks like is should work on my system... i just wanted to double check before i purchased... im running a nvidia 4200TI right now.... :(
lol it has serverd its time and is now ready to be apssed on to my friend who is currently running nothing......
well i just purchased a XFX 6600GT cant wait till this bad mofo comes in!!!
I loved my TI4200.. what a great card :D
You will love your 6600GT. It much better than my 9800Pro, and tends to cost less! Hehe.
