will a 4870 x2 fit?
Have a tape measure you can use? Try measuring out from chassis card slot to 10.6 inches (27cm) and see if it runs into anything. You want a litle over that just to be sure.
Looks like it will fit.. but barely and will have to move one of my hdds.
it's basically the same size as my old 8800gtx, but the power connectors are on the side of the board, not the back, so it's a lot easyer for clearance... dunno how the gtx vs gts size is, but...
When I had a 260, it fit in the P182 but I had already taken the center hd cage out. Not sure if it will fit with it in.
I have both cases, and the 4870x2 will fit in either one. For the P182 you will need to remove the middle HD cage and use the bottom for holding your HD's instead.
