Will 4GB ram work in my computer?
detzx
I have 2GB now but I notice when I play vanguard I have sometimes 30-40mb free. :( I want to get 4GB so I don't have to worry about this, I can see it swap and it sucks. My motherboard is
ASUS A8N-SLI Deluxe Socket 939 NVIDIA nForce4 SLI ATX AMD
and I currently have
CORSAIR XMS 2GB (2 x 1GB) 184-Pin DDR SDRAM DDR 400 (PC 3200)
and I want to add another 2GB of the same kind so I can keep dual channel. First, will they board run and recognize all 4GB? I'm running XP Pro 64bit so I know that will work right?
64bit os.................................check
mobo supports 4 gigs.............check
You should be good to go..
