Wildly inconsistent video card temperatures
Dcamel
Recently, I've had very high temperatures in world of warcraft, running the game in DirectX9 mode and getting temperatures into the seventies Celsius. I've cleaned the thing fairly recently (two months ago) and that hasn't helped. What's all the stranger is that Bioshock Infinite, a much newer, nicer-looking game, is peaking at 49 Celsius. Any help?
All the fairy dust in WoW can be turned off to see if that is an issue.
fffff I read the wrong reading, it's CPU temperatures, not GPU, GPU has been steadily low. Suppose the rest of my query still stands, just that it's maxing out a different component than I thought. I did set WoW to lowest graphics setting preset, hopefully that helps. This does need to be moved to processors (AMD) if that's at all possible though, it's an AMD64 5600+
what resolution, what cpu, what cooler, what case etc, fill in the blanks.
Running at "low" on many games can actually cause more stress on specific components, in many games this massively shifts the performance from a gpu side to a far more heavy cpu side.
If the cpu is getting hot, then filling in the blanks of information can help, I do recommend a decent cpu cooler using decent thermal paste regardless, I really like MX4 myself, works well, good coverage, not that expensive, easy to clean, safe in case you happen to get some on something you probably should not etc.
WoW is very cpu biased to begin with, Bioshock I believe was heavier on gpu side so again it depends on many factors and just throwing out a "its getting hot" means next to nothing without really knowing finer details.
1280x1024 Resolution
1x Multisampling
Vsync off
Texture Resolution Low
Texture Filtering Bilinear
Projected Textures off
View distance, environment detail, and ground clutter all low
Shadow/Liquid quality low, Sunshafts and SSAO disabled, particle density low
The CPU is an AMD64 5600+ with a stock cooler, recently cleaned the heatsink and processor and applied fresh coolermaster thermal paste (cheap stuff, I know). It's all very garden variety stuff, but I still don't think it warrants the -eighties- celsius on an old game run at low settings, especially since this same system ran it much cooler a year ago. I dunno.
70 is fine, wow is a heavily cpu intensive game, unless it is giving you slowdown I don't see a problem cpus can heat from 70 celsius to 30 in one second just based on load, But you do need a upgrade man srs bsn
Get better thermal paste and apply it with a credit card if you want it to run in the 60's which is the suggested max operating temp.
Or get a cheap after market cooler and new thermal paste
55-70 is the spec temps, and no 70c is not "fine" something is wrong with that statement just the same as AMD idea that a 290x running at 95c is ok it was built for it, high temps can give bad performance AND can cause failures much faster.
If you changed thermal paste did you do a good job of it i.e not to much and not to little as this can and does make a fairly larger difference in temps given, I do doubt however that it hit in the 80s Celsius far as I know it would insta shut down or would have cooked it older AMD chips were not very tolerant to high heat at all.
You do not need a credit card I know lots of people do that but its a very crud way of doing it, a small grain of rice size in the dead center of the cpu IHS and "bolting" down the heatsink is more then enough pressure to take care of it spreading itself out you really do not need to be fancy with applying it as if you get any crap in it, if its not an even layer it can give bad results. The heatspreader and heatsink will level themselves out and can acutally do a far better job then you "smoothing it" as nothing is perfectly flat so what is the point of trying to ensure the thermal paste is?
anyways, redo the thermal paste, try to change resolution (if you can) or play with settings, granted a stock cooler on any chip sux well except for my core 2 E8400 which ran very cool to begin with so the stock cooler worked miracles, and well thing is if the chip ran hotter then it should for longer then it should it could have gotten "hurt" and this obviously could be causing issues.
I do support concept of a low cost aftermarket heatsink, AM2/AM3/AM3/FM2 basically all use the exact same heatsink so many coolers will work with nearly all AMD cpu for the past decade or so. Hyper 212, Artic cooling freezer 64 there is many choices that are superior to the stock coolers and are not all that expensive.
FYI depending on which thermal paste coolermaster was used it is actually pretty decent stuff made by a reputable maker
It's just your system. You are running a hot CPU in a CPU intensive game at a super low resolution that puts even more stress on the CPU.
I agree on the super low res, but they are not known to be hot running cpu they are nothing fancy in this, inefficient sure, now a P4 however considering this were HOT, Athlon 64 x2 were really not until you hit the 6k ones really, something else is causing this, could be an overclock, could be extremely bad cooling in the case, a hot room, poor thermal paste application, an overclock without him saying he has one etc.
28-37c idle 45-56c load or so is kind of to be expected with the stock cooler in many circumstances (hey what do you know just like many current chips) question in this, what kind of RPM or noise is the stock heatsink making, cause if it were hitting these temps and everything was fine the fan would be screaming bloody murder trying to keep it cool, if its not, then it could be that you do not have the bios set to allow the fan to spin at a high enough % to keep it cool, Artic Freezer 64 would be a good cooler choice.
I would swap thermal paste myself and make sure you are doing a good job in applying it, not that this is gospel
http://www.tomshardware.com/forum/245375-28-5600-temperature
when I had my 5600+ oh so many years ago playing BF2-2142-cod4 and numerous other games on the stock cooler in a very crappy designed case for cooling the hottest it ever got was 54c and that was with the stock wax based junk paste and with a slight overclock.
FYI just cause the game is newer and prettier does not mean much of anything, nearly every game and every application loads the system differently, examples, Furmark, Intel Burn Test, Prime95, Heaven DX11, the named Bioshock, and a very prime example, World of tanks, they will all load the system differently, a 100% load on a part say cpu in one game does not mean its the same as another game loading it 100%, there are many factors present here.
I would say check the thermal paste, and secondly check the sound of the cooling system, if its screaming due to high rpm and you can feel the air moving and it sounds "normal" not a bad scratching sound or whatever then its doing what it should.
high temp cpu lol, suppose he would faint seeing the temps modern parts get then huh?
You do not need a credit card I know lots of people do that but its a very crud way of doing it, a small grain of rice size in the dead center of the cpu IHS and "bolting" down the heatsink is more then enough pressure to take care of it spreading itself out you really do not need to be fancy with applying it as if you get any crap in it, if its not an even layer it can give bad results. The heatspreader and heatsink will level themselves out and can acutally do a far better job then you "smoothing it" as nothing is perfectly flat so what is the point of trying to ensure the thermal paste.
Yeah it will die faster, but this thing is already that old man, you can't hold onto it forever even at 70 degrees if ita not shutting itself down I doubt it woukd die inside of a year. But the chip dieing is natural progression in life, the thing needs to be replaced, which is possible for 200 with better performance, when technology dies it makes you stop procratinating.
Also thermal paste, I have enoguh thermal paste to fill a bathtub l, srs ban I have tona of as5, mx2/mx4, Clu/Clp tubes ita rediculous, I've tried compression and it is not a superior as something actually spreading it with a credit card good
Just a thought if you take all the time in the world to flatten it, as soon as you put the heatsink on it will squish it the way it sees fit and YOU CAN trap air and crap in the thermal paste. You may not see or understand this side, but the whole point of the dot in the dead center of the IHS is not because is superior to all other methods, its because it simply works, is way faster to do, less likely to have various issues, and provides a pretty static perfectly repeatable result that does not vary by much compared to all other methods, do it once check the layer, clean, do the same way leave it, can be done in like 5 minutes flat.
1/2 size of bb or basically a grain of rice size for most thermal paste dead center of the IHS is ample, fast, provides proper coverage in a proper way more often then not etc. If for some reason say you have AS5 on it (or others similar to its composition) and the "seal" got broken on the cpu after ~6 months of use the temps will start spiking as the thermal paste is no longer in proper contact no matter the way you applied it. Whatever makes you happy I suppose.
Anyways, in general bad thermal paste or bad contact with the heatsink can very much cause bad temperatures. If it is getting that hot I seriously doubt because it is old but can agree on the if it is and has ran that hot without shutting down (and he has personally used or has been used for years) it probably is time to get a new one anyways (unless he mixed Fahrenheit with Celsius cause he did mix gpu and cpu temps :p)
Hmm a decent motherboard, cpu, ram, and possibly the OS to take advantage of it all for $200 (that will be worth that $200 say compared to spending $250 or $300 even) cheaper to buy a decent heatsink that will work with the newer chips just as well :)
http://www.hardwaresecrets.com/article/What-is-the-Best-Way-to-Apply-Thermal-Grease-Part-1/1303/11
"It seems to be irrelevant that the thermal compound covers the entire CPU surface, since most of the heat is produced at the middle of the processor heatspreader. In addition, it is a well-known fact that a CPU heatspreader is a little concave rather than really flat."
http://rog.asus.com/forum/showthread.php?30494-Proper-Thermal-Paste-Application
"Personally, I use the rice/pea/dot/grain in the middle method. If we dissect a Sandy or Ivy Bridge CPU, we'll find a small die in the center of the chip. This is the source of the heat. True, when we put a heatspredder on top of it, it transfers or spreads out the heat to the entire portion of metal. Nevertheless the center of the heatspredder is still the hottest part because it's in direct contact with the CPU die. That's why a lot of us use the dot method. To make sure that the center is properly coated with thermal compound. Then when you apply pressure to the heatsink or CPU block, it spreads out to the other areas.
I remember reading an article ages ago that evaluated the different methods of applying thermal compound. I don't have the link at hand right now but you can google it. In summary, of all the methods tested, the best one was the dot method. The difference isn't big either, maybe 3-5 degrees. But hey, when you're overclocking, every degree counts!"
