Wii does HD...???
Ashton
I was chatting with a guy the other day who claimed he was able to render HD on his Wii (that is display an HD video in true 1080p resolution). Unless I'm mistaken about the chip, the GPU in the Wii would be strained to give 800x600, much less 1920x1080.
Possible or complete BS?
The wii emulator is pretty polished for a console thats "this" new IMO. So many games run perfect at 1080p resolution...on the PC.
But no, the wii itself is not able to drive a 1080p resolution. You can see how a mario galaxy 2 runs and looks on 1080p here
http://www.youtube.com/watch?v=m9LdZ-x3TzA
It almost looks as if it were running on a 360 or something. Hopefully emulation will improve cause the difference is astronomical.
You're talking about video right?
It depends, higher resolution video takes more effort to decode but how much CPU/GPU time you spend decoding depends far more on what sort of video format you're using, the codec you're using to compress the video/audio and what sort of quality or bitrate you've picked.
Playing raw video which isn't encoded isn't very demanding at all, for example fraps records realtime video from your computer and encodes it on the fly because the default fraps codec is very lite and does virtually no compression. The trade off is that HD content is about 1Gb per minute of video.
I was under the impression that the Wii could only render 480 x 640, and uses anamorphic widescreen to fill out the 16:9 format.
Well what resolution you render at is more of a software issue not a hardware one, with the right software the Wii should be able to render a 1080p image, and display that to a screen if it has connectors that support resolutions that high.
The WII renders at 480P Widescreen max with component adapter. It can be "upscaled" to 1080P with third party emulators.
There are other limitations...
IE: The framebuffer on the Wii is 3mb...which isn't big enough to fit a 1920x1080 32 bit color image.
Really, if the system was only designed to output 480p, why would they waste the money of putting hardware capable of more in it.
What I've noticed is some people with 16:9 TV's are not changing the Wii output to 16:9. This is what he may mean.
But yes, if you switch it to 16:9 and buy component cables, your going to notice a lot better graphics than 4:3 480i with composit. Textures will be more sharp and text easier to read.
You must mean 640x480 but yes I heard that it renders in 640x480 then outputs it to 720x480. While there may be some stretching going on it's not very noticeable and the effect is pretty similar. I'm just glad the Wii can do some form of Widescreen.
That would be really weird since 720x480 is 1.5:1. DVD resolution is 720x480 and either stretches to ~852x480 (16:9) or squeezes to 640x480 (4:3). I'd imagine the Wii doing something like this.
Probably, not really sure to be honest. I know it looks pretty good on my 480p widescreen tv that does 852x480 natively. I don't even care that it's stretched. 720x480 stretched isn't really that bad. I'm pretty sure the 4:3 mode renders at 640x480 and the widescreen renders at 720x480 then stretches. Not sure exactly though.
Wii hardware is fixed to 480p.
Dolphin emulator on PC will do 1080p.
Just a reminder guys, some limited discussion of emulators is alright, but please make sure you don't link to or provide any type of instruction on how to get them. If you do I'll have to get out the rod of correction. ;)
I introduce that to my girlfriend every other night :D
Its a shame that Sony and Nintendo don't release optimized and licensed emulators for PC distributed along w/ games on Steam.
I have a PS3 Slim, but lets not kid ourselves, its crap compared to a decent gaming computer, and I would gladly pay to not have to have a Wii, PS3, and Xbox redundant gaming consoles to be able to play all the games out there w/ various hardware limitations (especially on the very lackluster performance Wii).
Many Wii and GC games look awesome at 1080p because the art direction is so good. Pretty stupid of them not to ever make a console that will render these games in higher resolutions.
